Rode the bike to work today got home and my new tires and tube had been delivered. So I installed the front tire, took the bike for a short ride not even a mile and it wasn't running correctly.... Don't know why ran fine on the way home from work, only thing that has changed is the new front tire... I found that it isn't running on the right cylinder i could operate the right carb and the engine wouldn't rev any, left side would. I pulled the plug and cranked it and it is firing. But I swapped the plugs from left to right and now it won't do anything. Both plug fire out of the cylinder but when installed they wont. I now this because they will not trigger the timing light when in the cylinder.... I was checking to make sure it hadn't jumped time. with the plugs out it will fire the light and the timing is spot on... I also looked at the valves through the plug hole to make sure the cam wasn't out of time as well, far as I can tell it looks good to... I guess the plugs are just fouled..... I don't know what happened I looked at them last week and they looked great nice and golden... but today they were a little carboned up but I have seen a lot worse that still ran... I'm going to get two new plugs tomorrow and see what happens....
