I got this 84 heritage special back in November, was able to get it for free after rescuing it from a shed. To say the least, it had seen much better days. The frame was hacked up pretty good, I'm guessing in an attempt to lower it, they welded in some much thinner bar stock and repositioned the shock mounts with some angle iron and very questionable welds. Also added was a rear fender and a tail from some other mystery bike. Here's the frame of that bike after the teardown. Fortunately all is not lost, as this frame is the perfect candidate for a bobber build.
I picked up a frame and title from a 79 XS and a new wiring harness locally as a good base for this build. I took the engine out to give it a once over and replace some basic things like filters and some of the seals, the oil pump a new kick clip donated by another member (thanks weekendrider!) After some new bolts arrive it's going back together and hopefully fires up without issue.
I just picked up a new seat pan locally today and drug out the new frame and my tank to see how everything's going to look. So far I like the direction it's starting to take, and I think the seat pan fits in nicely with the look of the GS 450 tank.
