Finally got tired of undersized thin paper things that look kinda like intake gaskets, so I got the cure and am passing it on: the Allpax kit cuts clean, precise round holes in gasket material, 2 cheap punches are included for small fastener holes, and there's a 14"x19" sheet of .060" thick (that's right, a full 1-1/2 mm.) genuine intake gasket material. The full unopened pack of Helix high density fiberglass muffler packing has enough in it for two or three wraps and rewraps of a pair of baffles--not that you'll need to do that much, the stuff is durable. There's a #4 starter gear with at least 80% of its service life remaining and clip tension at 5 lb. pull, a new Tsubaki "peanut" cam chain for 447 motors with rivet master link included, a digital micrometer on which the digits display randomly but the analogue numbers on the shank work fine. Not shown is a roll of common gasket paper.
