CDNTX650
XS650 Guru
Found this 1971 valiant for 5000 bucks. Zero rust....which is odd for a cdn a body..but it was an old lady's grocery getter after all. Last owner did tie rod ends, shocks, cap, rotor and wires, ball joints. 63000 miles . Decided since my dad was retiring there was no time like the present. Used the plans mr. Riggs put up here to make a points driven t.f.i. ignition with an accel 45kv coil. Found some dog dish hubcaps for it (not on yet) Rebuilt the accelerator pump. And just drove it and enjoyed it for the rest of summer. I even did valve lash...and you set it running!
Needs a few things over winter. Cylinder 6 plug is oily...good compression so I'll see if it needs stem seals...easy to do head on and cheap. Front crank seal has a small weep. Easy fix. Probably should do brake soft lines....guessing they are original.
Later stuff to do...Needs front seat cover and trunk mat. Weather stripping. Then eventually I'd like to get the body cleaned up and a same color re spray.
Good Ole buzzin half dozen 225 slant 6.
My dad worked on these cars when they were new. IIt's funny seeing the glint in his eye as he gets excited to work on these cars. Funny he always owned chevys though..always laughed at tinny shit box Moparsof the era
