Yes, the '83 has several added safety relays that earlier models didn't get (sidestand, clutch/starter). However, they are easily done away with if you want to simplify things. And I do recommend getting rid of at least the sidestand one. It's switch is mounted on the stand under the bike so is subjected to all the water, dirt, and debris kicked up from the road. It can and does go bad. And the relay associated with it acts upon the ignition black box, shorting it out and killing the spark, so if the switch or relay go bad, you are dead in the water.
