DeftQuiver
Hey Everyone,
First off, I just wanted to say thank you all for your part in creating what has to be one of the best motorcycle forums around... Although I love the XS for numerous reasons, the quality of this forum and its members played a huge part in my decision. I'm coming at this with very limited experience, but I've spent a ton of time reading up on this forum, And I plan to reference the posts I'm using to do my work as I go. My goal in this post is to both document what I need to do (to keep myself honest) and to compile some of the awesome threads and information so that some of the other new guys can more easily stumble upon some of the spectacular information I have found.
So now for the bike... I recently purchased a 1980 XS650 (Pics when I get home). It's actually in really good shape already, but I want to do some mild cosmetic changes, and get it into flawless mechanical shape. It's pretty much just been sitting around while I've been waiting for parts, but here's what's planned so far...
First and foremost, I'll be following this thread when I get home today...
http://www.xs650.com/forum/showthread.php?t=367
* Oil: When I change the oil (15/40 Diesel oil), I also plan to remove the sump filter to see if it's been damaged. If not, I'll probably throw it back in... If it's been damaged I'll probably be buying a new one from Boats.net and following the thread found here
* Battery is new
* Compression: I'll be checking the compression tonight and will post back with my results... Procedure found here
* Timing: TCI
* Carbs: Gas tank looks really clean inside, and I actually already cleaned the carbs and they appear to be in great condition. I used this article as a guide:
I also plan to install an inline filter tonight rebuild the petcock at some point using this post:
http://www.xs650.com/forum/showthread.php?t=20662&highlight=petcock (This one just popped up yesterday so I figured I'd give it a try... Thank you gggGary)
I've got a ton more planned, but this post is getting long, and this should be a good start. Thanks again for all the information... you guys rock.
Deft
* Battery is new
* Timing: TCI
Deft
