Hello all. I am in the process of replacing the stock taillight on my 1980 XS650 with a non-DOT approved single bulb light. I picked up the taillight that I am going to use and the wiring is very simple, a red and black lead connect directly to the bulb socket.
On the US 1980 XS650, the taillight is connected to the main wiring harness with a six prong plug, from this plug three wires connect to each bulb socket. It appears that the blue and yellow wires are positive and negative. I am not sure of the black wire, is it a ground? (See photo below)
The bulbs are Stanley 12v32/3CPBsr, I think that these are stock? And I think that the more common name for this bulb is #1157 dual filament.
I disassembled the bulb socket assembly and the bulb prongs are wired to the yellow and blue wires as expected. The black wire is attached to the bulb housing by way of spot weld.
The bulbs on stock have two filaments, the smaller filament is lit all the time when the bike is running. When the rear brake circuit is closed, the larger filament is lit in the bulb making the brake light brighter. This makes the light legal for night riding.
If I connect my new taillight to the yellow and blue wires on the stock wiring harness, when the rear brake circuit is closed the bulb filament lights up, this is great but I don't get the "always on" bulb filament to allow me to drive legally at night.
I want to modify the taillight that I bought to add several bright LEDs that will provide the constant light for night riding.
So here are my newbie questions to you knowledgeable folks:
1. What is this black lead? Is it related to lighting the larger filament in these bulbs or is it just a ground lead?
2. Is it possible that the 2 wire circuit has an increased voltage that is used to light the two filaments? It seems like that would be a clean way to design the light.
2. If it is not possible to use the 2 wires (blue/yellow) to have a constant and bright light, then do you have any ideas on how to modify stock 6 prong cable to provide constant and bright light modes?
Thank you all so much for your time and help. Hopefully these "newbie" questions will help somebody else in the community down the line.
