scabber
XS650 Guru
Nice job on the installation. What is your view on CVK vs BS 34 performance wise. I bet that those kick as 34's stay on the shelf.
They indeed destroy the 34s. The 34s are not going back on... This things pulls like a beast now. .
Low speed chain slap is your bike telling your in the wrong gear most of the time. If have changed sprockets for highway speeds it might be more prevalent. The 650 gearing not the best for stop and go to craw traffic. A bigger low speed jet might help if it is carb related.
If you have tip-in issues then you should try changing the needle diameter (last letter in the needle designation) instead of changing the pilot jet.
hello all,
Regarding the throttle cables couldn't these from Mikes be modded relatively easily to work on the EX500 carbs? http://www.mikesxs.net/product/48-9150.html
I have a set of ex500 carbs on the way now. Can't wait to install them.
Regards,
pyro
I modified a stock XS cable for single 'pull' , doing away with the 'push' option.
What size of pilots?
