OK so first off please bear with me.... I am at my wits end on this...
SO I have a new build, here are the components
1. New peanut harley style gas tank. (has a single petcock) doesn't have any sort or venting tubes, so I believe that the gas cap should be vented.
2. Have the stock Vm38 carbs on the engine. (stock jets etc)
3. The carb boots have the plastic barb covers on them.
4. The petcock has a single fuel line that runs to an inline fuel filter (clear) then to the T connector to the carbs.
5. New Pamco ignition
6. Pod filters
Here are the problems.
1. The fuel seems not to flow from the tank to the carbs freely. ( I can see the gas in the filter and it isn't running.
2. with the left side pod filter on and the right side off, I have to put my hand over the carb opening to seem to prime the gas into the carb/chamber. Once I have done that the engine turns over, runs for a few seconds then dies. If it does run for more than a few seconds, when I move the throttle it dies/chokes instantly.
My question is this......Is there a vacuum lock or something happening? Because of the style of tank do I need to vent the tank? Should these barb covers on the boots be open or running a line off them? I seems that the reason the gas isn't flowing is that the gas isn't coming from the tank to the carbs fast enough or at all.
Can someone please shed some light on this :bang head:
6. Pod filters
