MB Canada
flying the chair
I have been trying to dial in my new motor. I had been trying to firstly get my timing retarded enough to actually fall into the "F" section (best it seems to go was 1/4 inch or so before the "F" marking at idle. After my ankle healed from the wicked kick backs i had read a few more very helpful threads and realized i may not have had the cam chain tight enough? I was wondering if i had missed something during the build as i had the cases split, but i checked the timing marks more than once. I have a Pamco ignition with the green dual wire coil. Turns out the cam chain was too loose BUT after checking the timing (Pamco still totally retarded but just hitting "F" mark) when i disconnected the timing light i VERY STUPIDLY missed putting the plug cap back on the spark plug. I kicked it over and the motor fired when i looked down (maybe 10-15 seconds) i put the cap back on the plug while running. The cylinder fired right up.....10 min later no spark!! Fuses are fine and i have good power to coil (red w/wht strip wire) nothing after that. I also installed new ATU springs with mod to spring snaps back like the video posted. I have been really struggling with the timing way too advanced, after the cam chain was tightened (wiggly thingy stopped then backed of until movement again while running hot) the timing got barley within spec (3500 rpm was on the mark) but why is the Pamco all the way to it's end?? Through this whole process, i thought maybe the new cam chain was my issue... still my motor breaks up between 4 and 5000 rpm. Struggling wondering if it's a timing issue or jetting as the rpm seems to be when the two jets transfer? Well i have VM 34 's from MMM and he's the man. I went size larger main.. just got richer as well tried a 30 slow speed jet (MMM set up was 27.5) but way too rich. I think MMM had it jetted fine the first time!
Sorry for my very winded tale... the big question is when i ran the bike without a plug wire connected... ya think i blew coil as well as the pamco? I have another coil here from a Harley setup so i can try that.... i was seeking some wisdom on my matter as i know it was own fault not having the plug wire connected. I had also tried spinning the shaft through the ATU 180 and have timing marks lined up with the ATU weights rotor.
Why would my timing be so oddly cranked full retarded only to barley hit the beginning of an acceptable setting?
Frustrated with a sore ankle and now wondering how much of my ignition did i just fry?
