tesla
I have to admit I was a tad bit sceptical about the abilities of the PAMCO. With all the hype I have been sitting on the fence as to whether or not the PAMCO system does bring benefit vs. a point system that for all intensive purposes works just fine.
My scepticism was absolutely squashed yesterday when I received my PAMCO in the mail. In short..... I was wrong.
I installed with ease and used a Mikes XS 17-6810 coil.
Within an hour and a half I had set the timing and was on the road.
Some points: (pun intended)
-The idle is far smoother.
-I could set the idle below 1000 rpm with no issue if wanted.
-There is a marked improvement in acceleration and smoothness. (I'm tipping a tad more power too)
-deceleration was also far smoother.
-I now have to adjust clutch as when riding hard as there is a little slip due to bump in acceleration ability. Hah, who would have thought.
I do however have one question for Pete, What is the optimal distance for the magnet to hall effect sensor? is there a benefit to being closer or further away from flux field?
most advance rods have a little play so this change in distance will change the flux position. Just curious.
So shit... this thing rocks, If you have doubts.... think twice. I'm glad I did.
Thanks Pete.
76 with home made PMA swap.
Thanks Pete.
