Wanted - PAMCO WITH E-IGNITION
timbeck
HARDLY A GURU
XS650.com Supporter
XS650.com Supporter
Boston,MA
I AM LOOKING FOR A PAMCO WITH THE E-IGNITION TO REPLACE MY CLAPPED OUT ONE. ANY HELP IS APPRECIATED, THANKS
tim
I believe the E-Advancer was with the small blue box and the E-Ignition is all built onto the ignition plate.
tim
The final edition was both on the plate under the cam end cover.
Thanks azman, that's the one that I am looking for.....or I need to consider a Boyer or what ever is going to be the "go to " ignition system......
tim
650skull I checked with Pazon and they do not offer an ignition system for our bikes but maybe in the future.
email from Andy at Pazon below:
Hi J-C,
Thanks for contacting us.
As you may know, we don’t make ignitions specifically for the XS650 at present (we have an ever-growing to-do list!).
The nearest kits we have are the ones for the British twins (Sure Fire, Altair or Smart Fire).
The trigger assembly for the British twins is 68.1mm diameter.
The contact-breaker assembly for the XS650 is an unusual shape, so some ingenuity would be required to get our trigger to fit (perhaps mounting onto the bare original contact-breaker plate), all held in place with suitable spacers and bolts.
Our rotor has a male taper, so this also would need to be modified to suit (perhaps machined from tapered to straight).
Some M8 studding, nuts & washers would also be required to lock our rotor into the camshaft.
(Our rotor has an M8 centre thread).
We will let you know if we do develop a system specifically for the XS650.
Best regards,
Andy Perkins
PAZON IGNITIONS LTD.
Keeping Classic Bikes on the Road
www.pazon.com
Skull, I also sent a note to Pazon and got the same answer. Andy did note that he has had a few inquiries about XS650's so who knows
tim.
