Scallywag303
Frame has no title, bike was sitting outside for unknown length of time.
The engine is seized, the right pipe was not on and the valve is rusted(guessing that is why), but it did have oil so crank and cases may still be good, rocker cover is good so is cam havent taken head off yet, so if anyone wants internals or anything off the motor I'll strip it down and part it out.
Prices INCLUDE shipping and are ish obo anything left attached to frame make offer
Updated 6/14
-Gauges and dash panel no ignition switch $35
-Front caliper/bracket/lines (right side) $30
-Front Axle/parts $20
-Forks $45
-Cam shaft and bearings looks great I can send a pic $50
-Motor mounts. Ill send the bolts also less a couple of the top for what I needed $40
-points set up every stock part advance rod, pins, screws, cam, and points $55 (mechanical advance sold rest available still)
Anything else just ask I have no need for any of this so like to see it go to good use and not sit on my shelf for 10 years
-Triple trees SOLD
-Rear disc setup swing arm, brake stay, caliper, bracket, lever, brake pivot, master cylinder and line, I'll take the rotor of the wheel too if someone needs it (complete everything you need, brake lever is bent a tad) SOLD
-Valve covers SOLD
-Timing Covers SOLD
-Rear fender liner SOLD
-Rear axle SOLD
-Carbs and boots(unknown model and condition but likely stock for year) SOLD
-Set of mag wheels SOLD
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Swing arm is surface rust only nothing is rusted through
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Original yamaha key is included and turns but the hey hole part is broken for the key ring
Updated 6/14
-Forks $45
-Triple trees SOLD
-Valve covers SOLD
-Timing Covers SOLD
-Rear axle SOLD
