Yamaha xs650 xs tx Lot of brake lines hoses
From a couple of parts bikes. Some front top lines, from bottom lines, possible a rear line in there. All look to be in good working shape. I trash any hoses that are cracked.
$5
Yamaha xs650 xs tx 650 1972 Rear brake lever
Should be cleaned OK. Good working shape.
$5
Yamaha xs650 xs tx 650 1973 Rear brake lever
$5
Yamaha xs850 xs 850 1973 Rear brake lever
Chrome looks good, good working shape.
$5
Yamaha xs650 xs 650 1978 Standard Exhaust Headers
A bit rusty. Could be covered with exhaust wrap, or cut the ends off for your customer exhaust.
$20
Yamaha xs650 xs 650 1979 Special shocks
OK shape, missing rubber inserts.
$5
Yamaha xs650 xs tx Lot of cables, 1972 and 1973
Some speedo and tack cables throttle and clutch.
$5
Yamaha xs650 xs 1977 full clutch
It's marked 1972, but I'm sure it's off a 1977 engine.
$10
Honda cb 650 Mirror
Rough but usable shape
$2
Yamaha xs650 xs 1972 Front Axle
Good working shape.
$5
Yamaha xs650 xs Shift lever
Good working shape, should fit all years.
$5
Yamaha xs650 xs 650 Special 80-83 Right Side cover
No broken tabs or cracks. Could use some fresh paint.
$5
Universal Japanese motorcycle 2:1 Speedo, for parts
Bought for a xs650, used and then speedo needle started acting strange and bouncing all over. For parts, bought from MikesXS.com
$2
New Universal Chopper turn signal, duel filament
New in original plastic. Duel filament bulb. 2 inch diameter.
$5
New 1 inch handle bar turn signal mounts, Duece
These are for mounting Harley Davison Duece style turn signals to the handle bars. Never used.
$10
2 New Duece Style clear turn signal lenses
New never used ($3.50 each new)
$5
New never used ($3.50 each new), but out of packaging.
$2
1 New Duece Style clear turn signal lens
New never used ($3.50 each new).
$2
Yamaha xs650 xs 1972 Rotor and Stator Alternator Set
Resistance between the rotor rings is 5.6 Ohms. Brushes look like they should be replaces and there is a grove in
the rotor from one of the brushes
$10
Yamaha xs650 xs 650 1978 Rotor and Stator Alternator Set
Resistance between the rotor rings is 5.7 Ohms. Brushes look still look good.
$20
82 Honda cb650 Regulator Rectifier.
Replaced when trouble shooting a charging issue that turned out to be a bad rotor, so I think this is in good working condition.
$5
Yamaha xs650 xs 650 New Point set
Still in plastic, never used.
$5
Yamaha xs650 xs 650 Rear foot peg rubber
New Old Stock rear foot peg rubber. I bought these think they were front, so I never used them.
$5
$5
$5
$5
$5
$20
$5
$5
$10
Honda cb 650 Mirror
$2
Good working shape.
$5
$5
$5
$2
$5
$10
$5
$2
$2
$10
$20
$5
$5
$5
