Got everything back together and she looks a treat. Unfortunately, like most back-yard mechanics, I am filled with doubts about my ability to complete the job correctly. Am lying awake at night wondering about the master link on the cam chain. Did I fit it correctly. I used a cheap Chinese riveter and suffered the common problem of pin slip off the link post. The job looked OK at the time but now I have my doubts. The thought of that chain doing 3000 revs with a poorly fitted master link is giving me cold sweats. Poured over some relevant threads and it would appear that the consequences of link failure are worth an inspection before I re-install the motor. So...... can I remove the head cover, (It has 1104 on it), inspect and peen the link, (to satisfy my feelings of inadequacy), clean the top surfaces up and re-install everything without needing to replace the head or base gaskets. They are copper sprayed. I would rather not pull the jugs off again. Opinions? I promise I will be careful!
