Glad you like it! I removed the rubbers with excessive force, bad language, hammer and chisel. I guess you should be able to pull them out but mine just ripped off the inner part and the outer sleeve was stuck in the hole. Be careful while hammering. I almost ruined the shoulder on the bottom of the holes where the rubbers sit.
The new bushing were (if I remember correctly) 30mm solid "aircraft grade" aluminum bar that was a tight slip fit to the holes. The Loctite 638 should be more than strong enough to hold them in place. Threads were 12mm "fine thread".
Pekka
