Yes, that needs the holes. It's not a problem really, though, because pretty much all you can readily get are the ones with holes. In your case, VM22/210 style w/ bleed holes.
This all has to do with how the pilots mount and how fuel and air is delivered to them. Your VMs mount the pilot up into the main body in what is considered the "normal" fashion. Fuel is drawn up through the screw slot end of the jet from the bowl and air is delivered to the side to mix with it. That's why you need the bleed holes, to allow the air to mix in. The BS34s mount their pilots in a similar manner and get their air the same way so they need the bleed holes, too.
