Hey guys, I put an 11mm front master cylinder on my build using the stock single piston caliper. It works, but requires way too much lever travel and doesn't feel very powerful at all. I'm running a drilled rotor and stainless one piece hose. I got the 11mm MC from a Zuma and noticed that the caliper piston on the Zuma is much smaller than the XS one. Could that have something to do with it? I thought the 11mm bore was the hot setup for the single disc rotor but doesn't feel good at all. Is anyone else running an 11mm bore MC with the stock caliper and if so, how is it working for you?
