John...thanks for the picture...neat arrangement. My bike was built in late '78, making it a '79, I think, though I've never checked the numbers, but could easilt enough. It had pods on it when I bought it, and the vent lines were just hanging down. I don't have the original airbox. So would you bother piping it into the pod, or maybe switch to the single port vent, then tubing to the valve, then maybe a T in the line to connect the small pod like Gordon has, then another inch or two of tubing with a plug in the bottom, to catch any oil, that comes out.
If I did pipe it into the carb pod, would it be acceptable to vent it into one, or should I stick with the double vent port, and pipe it into both carb pods?
Sounds like the first option might be best, single port, line, valve, mini-pod, and drain plug. What do you guys think?
