Postal charges.
toglhot
First class butcher.
Adelaide
Ridiculous postal charges:
Two circlips from the Netherlands (Heidens) = 45 euros
Two circlips from the US (Z1 enterprises) $135
Two circlips from the US (mikesxs) $79
Two circlips from England (Yambits) £13
Two circlips from Australia (Geoffsxs) Bought some circlips from hIm, apparently he doesn't know there are different size piston pins. Same bloke thinks it OK to have 3-4mm of thread showing on spokes.
Add to that the cost of the circlips
Heidens. 2.89 euros plus postage 45 euros 48 euros $86Aus
Z1 $4.80 plus postage $135 $140Aus. $220Aust
Mikes $4.80 plus postage $79. $84. $132Aust
Yambits. £3.14 plus postage. £13. £15. $28Aust
Australia, $8.50 £5 $14. $19 but it doesn't matter, he doesn't know there are different size piston pins.
For two piston pin circlips, Circlips are 20mm round and 1.2mm thick and weight the equivalent of three mickey hairs.
Where the hell do they get these prices? Z1 enterprises are out of their cotton picking minds, $220 for two circlips.
I'll try some local bike shops tomorrow. Unfortunately, most have never heard of an XS650.
If I ever get to the states again I won't be posting any postcards back to Oz, that'd cost more than the trip over there.
I have some used ones here from XS 650's . Not ideal to reuse them but if you can't get new for a reasonable all up price just ask.
Thanks, but after emptying the bin and going through the rubbish without luck, I crawled around on the workshop floor with a torch and two pairs of glasses for about an hour and found the two originals, then the wife wheeled the engine crane into the workshop hooked me up and lifted me off the floor. So I'm right there.
I'll ring around this morning and see if anyone has Wiseco CW20 in stock.
I have reused piston pin circlips before without any problems, I'm just a little reluctant on this build given the amount of work I've put into the thing.
Did you know there is a correct way in which to orient piston circlips??? New one on me, but it makes sense I guess.
Why not get them from your local yamaha dealer?
93450-22027-00 CIRCLIP
CIRCLIP​
93450-22027-00​
by Yamaha
$6.99 18% OFF
$5.76
They don't keep parts for bikes older than about 6 months old. Parts are listed by bike models. If there were alternatives that would fit from another bike, they have to get off their fat arses and go through their catalogues, much, much too hard for them.
I just gave you the Yamaha part #
This Yamaha 93450-22027-00 CIRCLIP fits the following models and components:
Yamaha Power Equipment YG500D Crankshaft Piston
Yamaha Power Equipment EF4000DVE Crankshaft Piston
Yamaha Power Equipment EF5000DVE Crankshaft Piston
Yamaha Power Equipment EF5000DV Crankshaft Piston
Yamaha Power Equipment YG600D Crankshaft Piston
Yamaha Power Equipment YG650DE CRANKSHAFT PISTON 2
Yamaha Power Equipment YG650D CRANKSHAFT PISTON 2
Yamaha Power Equipment YG550D CRANKSHAFT PISTON 2
Yamaha Power Equipment EF5000EA CRANKSHAFT PISTON EF5000EA
Yamaha Power Equipment EF6000EA CRANKSHAFT PISTON EF6000EA
Yamaha Power Equipment YP40T CRANKSHAFT PISTON YP40T
Yamaha Power Equipment YG650DE CRANKSHAFT + PISTON (1)
Yamaha Power Equipment YG550D CRANKSHAFT + PISTON (1)
Yamaha Power Equipment YG650D CRANKSHAFT + PISTON (1)
Yamaha Power Equipment EC4000DV CRANKSHAFT - PISTON (EC4000DV)
Yamaha Power Equipment EF5000DV CRANKSHAFT - PISTON (EC4000DV)
Yamaha Power Equipment EF5000DVE CRANKSHAFT - PISTON (EC4000DV)
Yamaha Power Equipment EF4000DV CRANKSHAFT - PISTON (EC4000DV)
Yamaha Power Equipment EC5000DV CRANKSHAFT - PISTON (EC4000DV)
Yamaha Power Equipment EF5000DVE CRANKSHAFT - PISTON (EC5000DV(E))
Yamaha Power Equipment EF4000DV CRANKSHAFT - PISTON (EC5000DV(E))
Yamaha Power Equipment EC5000DV CRANKSHAFT - PISTON (EC5000DV(E))
Yamaha Power Equipment EC4000DV CRANKSHAFT - PISTON (EC5000DV(E))
Yamaha Power Equipment EF5000DV CRANKSHAFT - PISTON (EC5000DV(E))
Yamaha Power Equipment YG600DE Crankshaft Piston
Yamaha Power Equipment EF6000E Crankshaft Piston
Yamaha Power Equipment EF5000E Crankshaft Piston
Yamaha Motorcycle 1979 XS650_2F CRANK & PISTON
Yamaha Motorcycle 1979 TT500F CRANK & PISTON
Yamaha Motorcycle 1978 SR500E CRANK & PISTON
Yamaha Motorcycle 1978 XT500E_205 CRANK & PISTON
Yamaha Motorcycle 1979 XT500F CRANK & PISTON
Yamaha Motorcycle 1973 TX750 CRANK & PISTON
Yamaha Motorcycle 1974 TX750A CRANK & PISTON
Yamaha Motorcycle 1979 SR500F CRANK & PISTON
Yamaha Motorcycle 1977 XT500D CRANK & PISTON
Yamaha Motorcycle 1976 XT500C CRANK & PISTON
Yamaha Motorcycle 1975 XS650B CRANK PISTON TX650A - XS650B - C
Yamaha Motorcycle 1974 TX650A CRANK PISTON TX650A - XS650B - C
Yamaha Motorcycle 1977 XS650D CRANK PISTON XS650D E E006501- F
Yamaha ATV 2000 KODIAK 2WD - YFM400AM Crankshaft Piston
Yamaha ATV 2000 KODIAK 4WD REALTREE X-TRA - YFM400FAHM Crankshaft Piston
Yamaha ATV 2000 KODIAK 2WD - YFM400AMC Crankshaft Piston
Yamaha ATV 2000 KODIAK 4WD - YFM400FAMC Crankshaft Piston
Yamaha ATV 2001 KODIAK 4WD_HUNTER - YFM400FAN Crankshaft Piston
Yamaha ATV 2008 GRIZZLY 400 4WD - YFM4FGXR Crankshaft Piston
More
Yamaha ATV 2014 YFZ450R - YFZ450REO Crankshaft Piston
Yamaha ATV 2014 YFZ450R SPECIAL EDITION - YFZ450RSER Crankshaft Piston
Yamaha ATV 2008 GRIZZLY 450 4WD - YFM45FGXR Crankshaft Piston
Yamaha ATV 2006 KODIAK 450 4WD HUNTER_OUTDOORSMAN - YFM45FAHV Crankshaft Piston
Yamaha ATV 2011 YFZ450X - YFZ450XAL Crankshaft Piston
Yamaha ATV 2014 GRIZZLY 450 - YFM450DEL Crankshaft Piston
Yamaha ATV 2007 GRIZZLY 450 - YFM45FGW Crankshaft Piston
Yamaha ATV 2014 GRIZZLY 450 - YFM450DEG Crankshaft Piston
Yamaha ATV 2007 GRIZZLY 400 HUNTER - YFM4FGHW Crankshaft Piston
Yamaha ATV 2012 GRIZZLY 450 EPS 4WD HUNTER - YFM45FGPHB Crankshaft Piston
Yamaha ATV 2012 GRIZZLY 450 4WD - YFM45FGBL Crankshaft Piston
Yamaha ATV 2013 YFZ450R - YFZ45RDW Crankshaft Piston
Yamaha ATV 2012 YFZ450R - YFZ45RBW Crankshaft Piston
Yamaha ATV 2008 YFZ450 SPECIAL EDITION II - YFZ450SP2X Crankshaft Piston
Yamaha ATV 2002 KODIAK 4WD HUNTER - YFM400FAHP Crankshaft Piston
Yamaha ATV 2003 KODIAK 450 4WD - YFM450FAR Crankshaft Piston
Yamaha ATV 2003 KODIAK 4X4 CAMO HARDWOODS - YFM400FAHR Crankshaft Piston
Yamaha ATV 2003 KODIAK 400 2WD - YFM400AR Crankshaft Piston
Yamaha ATV 2006 KODIAK 400 4WD - YFM4FAV Crankshaft Piston
Yamaha ATV 2024 KODIAK 450 EPS HUNTING - YFM45KPHRF Crankshaft Piston
Yamaha ATV 2024 KODIAK 450 - YFM45KDXRL Crankshaft Piston
Yamaha ATV 2023 YFZ450R SE - YFZ45YSSPD BKDK Crankshaft Piston
Yamaha ATV 2023 YFZ450R - YFZ45YSXPL BKDF Crankshaft Piston
Yamaha Motorcycle 1978 XS650SE-11 Crankshaft Piston
Yamaha Motorcycle 1980 TT500G Crankshaft Piston
Yamaha Motorcycle 1980 TT250G Crankshaft Piston
Yamaha Motorcycle 1980 SR250G Crankshaft Piston
Yamaha Motorcycle 1976 TT500C Crankshaft Piston
Yamaha ATV 2007 GRIZZLY 450 HUNTER - YFM45FGHW Crankshaft Piston
Yamaha ATV 2007 GRIZZLY 450 OUTDOORSMAN EDITION - YFM45FGOHW Crankshaft Piston
Yamaha Motorcycle 1977 TT500D Crankshaft Piston
Yamaha ATV 2008 GRIZZLY 450 HUNTER - YFM45FGHX Crankshaft Piston
Yamaha ATV 2009 YFZ450R (BLUISH WHITE SOLID 1) - YFZ450RYW Crankshaft Piston
Yamaha ATV 2009 YFZ450 - YFZ450YW Crankshaft Piston
Yamaha Motorcycle 1986 VIRAGO 700 - XV700CS Crankshaft Piston
Yamaha ATV 2004 KODIAK 450 AUTO 4X4 - YFM45FAS Crankshaft Piston
Yamaha ATV 2022 YFZ450R - YFZ45YSXNL BKD8 Crankshaft Piston
Yamaha ATV 2012 YFZ450R SPECIAL EDITION - YFZ45RSEB Crankshaft Piston
Yamaha Motorcycle 1995 VIRAGO 750 - XV750GC Crankshaft Piston
Yamaha ATV 2023 KODIAK 450 EPS SE - YFM45KPSPL BEYM Crankshaft Piston
Yamaha ATV 2006 YFZ450 SPECIAL EDITION - YFZ450SPV Crankshaft Piston
Yamaha ATV 2023 KODIAK 450 - YFM45KDXPG BJ5V Crankshaft Piston
Yamaha Motorcycle 1986 VIRAGO 700 - XV700SSC Crankshaft Piston
Yamaha ATV 2023 KODIAK 450 EPS - YFM45KPAPG BEYP Crankshaft Piston
Yamaha ATV 2004 KODIAK 400 4X4 - YFM4FAS Crankshaft Piston
Yamaha ATV 2003 KODIAK 400 4WD - YFM400FAR Crankshaft Piston
Yamaha ATV 2008 YFZ450X (DEEP PURPLISH BLUE SOLID E) - YFZ450XL Crankshaft Piston
Yamaha ATV 2005 KODIAK 450 4WD - YFM45FAT Crankshaft Piston
Yamaha ATV 2005 KODIAK 450 4WD BLACK-CARBON - YFM45FASET Crankshaft Piston
Yamaha ATV 2005 KODIAK 400 4WD HUNTER - YFM4FAHT Crankshaft Piston
Well, isn't that amazing, I've called them before for parts, gave them the part numbers and so on, they've had absolutely nothing and are not very helpful at all.
But I just rang them and would you believe it, they have two in stock.
I'm astounded. I can't even get filters from them, points, you gotta be kidding. Gaskets, hahahaha! I had one guy ask if an XS650 was a jetski.
A warning to anyone using these part numbers. I picked up two clips this afternoon. 93450-22027-00
Despite what the list states, these do not fit post 74 models. They are for pre 73 models.
Post 74 models are 1.2mm wire and for 20mm gudgeons, pre 73 models are 1.4mm wire and for 22mm gudgeons. I have two pre 73 circlips and these are identical.
The free diameter of the pre 73 model circlips is also larger, the ends touch before the diameter reduces enough to get them into the piston gudgeon hole.
So, you'd have to snip a bit off the end of the circlip to make it fit, the diameter of the wire is also bigger than the groove so you'd risk the circlip popping out.
the size for post 74 models is documented on various sites. wiseco make a 20mm wire circlip, 1.2mm thick, part number CW20. I have one on order from ebay.
The bore in the piston is 20mm, the clip groove is 1.2mm wide. The clip would sit in the groove for half of its thickness, so the diameter of the groove would be 21.2mm. Any more and the pin would likely slip over it, any less and the pin would push the clip out.
The free diameter of the pre73 model clip is 23.8mm, much to big for the post 74 gudgeon bore of 21.2mm without snipping a bit of the end of the clip. And then trying to compress from 23.8 down to 21.2 is not easy. .2mm might not sound like much, but the effort required to compress the extra .2mm is considerable.
interesting; were they in unopened factory packaging?
This Yamaha 93450-24028-00 CIRCLIP fits the following models and components:
Yamaha Motorcycle 1972 XS2 CRANK & PISTON
Yamaha Motorcycle 1970 XS1 CRANK & PISTON
Yamaha Motorcycle 1973 TX650 CRANK & PISTON
Yamaha Motorcycle 1971 XS1B CRANK & PISTON
Yamaha ATV 1998 GRIZZLY - YFM600FWAK Crankshaft Piston
Yamaha ATV 2000 GRIZZLY REALTREE - YFM600FHM Crankshaft Piston
Yamaha ATV 2008 GRIZZLY 660 HUNTER - YFM66FGHX Crankshaft Piston
Yamaha ATV 2008 GRIZZLY 660 - YFM66FGXR Crankshaft Piston
Yamaha ATV 2008 GRIZZLY 660 - YFM66FGXGR Crankshaft Piston
Yamaha ATV 2007 GRIZZLY 660 - YFM66FGW Crankshaft Piston
Yamaha Boat 2012 242 LIMITED S - SXT1800HL Crankshaft Piston
Yamaha Boat 2013 212SS - XAT1800CM Crankshaft Piston
Yamaha Boat 2012 SX240 HIGH OUTPUT - SXT1800DL Crankshaft Piston
Yamaha ATV 2000 GRIZZLY REALTREE - YFM600FHMC Crankshaft Piston
Yamaha Boat 2010 SX240 HIGH OUTPUT - SXT1800EJ Crankshaft Piston
Yamaha ATV 2000 GRIZZLY - YFM600FMC Crankshaft Piston
Yamaha Boat 2011 242 LIMITED S - SXT1800HK Crankshaft Piston
Yamaha ATV 2000 GRIZZLY - YFM600FM Crankshaft Piston
Yamaha ATV 2006 GRIZZLY 660 SPECIAL EDITION - YFM66FASEV Crankshaft Piston
Yamaha ATV 2006 GRIZZLY 660 HUNTER_HARDWOODS - YFM66FABGH Crankshaft Piston
Yamaha ATV 2006 GRIZZLY 660 HUNTER_HARDWOODS - YFM66FABGG Crankshaft Piston
Yamaha ATV 2005 RAPTOR 660R - YFM660RT Crankshaft Piston
Yamaha Boat 2019 242X E SERIES - SAT1800EU Crankshaft Piston
Yamaha Boat 2019 AR195 - TP1800AU Crankshaft Piston
Yamaha ATV 2005 GRIZZLY 660 HUNTER WETLAND - YFM66FAHWT Crankshaft Piston
Yamaha Boat 2019 AR240 HO CALIFORNIA - SAT1800ALU Crankshaft Piston
Yamaha ATV 2004 GRIZZLY 660 AUTO 4X4 WETLANDYFM660FLES - YFM660FHSW Crankshaft Piston
Yamaha Motorcycle 1986 SRX600SC (CA ED.) Crankshaft Piston
Yamaha Boat 2018 SX190 CALIFORNIA - RX1800BLT Crankshaft Piston
Yamaha Boat 2018 242 LTD S CALIFORNIA - SAT1800CLT Crankshaft Piston
Yamaha Boat 2014 212X CALIFORNIA - XAT1800BLN Crankshaft Piston
Yamaha Boat 2014 212X - XAT1800AN Crankshaft Piston
Yamaha ATV 2004 GRIZZLY 660 AUTO 4X4 WETLAND - YFM660FHSWL Crankshaft Piston
Yamaha ATV 2004 GRIZZLY 660 - YFM660FS Crankshaft Piston
Yamaha Motorcycle 1986 XT600S Crankshaft Piston
Yamaha Motorcycle 1994 XT600EFC Crankshaft Piston
Yamaha Motorcycle 1991 XT600EB Crankshaft Piston
Yamaha ATV 2005 GRIZZLY 660 HUNTER - YFM66FAHT Crankshaft Piston
Yamaha ATV 2005 GRIZZLY 660 SE - YFM66FASET Crankshaft Piston
Yamaha Motorcycle 2001 V-STAR 1100 CLASSIC - XVS1100ANC Crankshaft Piston
Yamaha ATV 2004 RAPTOR 660R - YFM660RS Crankshaft Piston
Yamaha ATV 2003 RAPTOR 660R - YFM660RR Crankshaft Piston
Yamaha Motorcycle 1990 XT600EA Crankshaft Piston
Yamaha ATV 2003 RAPTOR BLACK LIMITED EDITION - YFM660RLER Crankshaft Piston
Yamaha ATV 2002 GRIZZLY HUNTER EDITION - YFM660FHP Crankshaft Piston
Yamaha Boat 2015 SX190 CALIFORNIA - RX1800DLP Crankshaft Piston
Yamaha ATV 2002 RAPTOR LIMTED EDITION - BLACK - YFM660RPB Crankshaft Piston
Yamaha Motorcycle 1999 ROAD STAR SILVERADO - XV1600ATLC Crankshaft Piston
Yamaha Motorcycle 1999 ROAD STAR - XV1600AL Crankshaft Piston
Yamaha Motorcycle 2000 ROAD STAR - XV1600AM Crankshaft Piston
Yamaha Motorcycle 1999 V-STAR 1100 - XVS1100LC Crankshaft Piston
Yamaha Motorcycle 2000 ROAD STAR - XV1600ALMC Crankshaft Piston
Yamaha Motorcycle 2000 ROAD STAR SILVERADO - XV1600ATM Crankshaft Piston
Yamaha Motorcycle 2000 ROAD STAR MM - XV1600ASMC Crankshaft Piston
Yamaha Motorcycle 2000 V-STAR 1100 CUSTOM - XVS1100M Crankshaft Piston
Yamaha ATV 1999 GRIZZLY - YFM600FWAL Crankshaft Piston
