justifiedman
My totally stock 1975 XS650 continues to have the same issue, a bad miss under heavy acceleration. I have less than 1500 miles on a professionally rebuilt engine. It ran perfectly until recently when the abrupt miss began. I have a new fully charged battery, new plugs. I have adjusted the cam tensioner, adjusted the valves, set the points (after lightly filing and cleaning them) set the timing, adjusted the carbs (in that order) and it did not change things.
I don't know if this is significant, but after setting the timing statically, I used my timing light and found that the timing mark was not steady, everything is blurred whether at 1200 RPM or 2000-3000 RPM. Also, when setting the carbs beginning with the 3/4 setting on the idle mixture screws (then using the method in the Factory Manual of pulling the plug wire off of one side and adjusting the other side) the right side responded as it should by speeding up the RPM while turning the idle mixture screw, but the left side was significantly less responsive upon switching over to doing that side.
Having looked over the possible causes in the "Trouble Shooting" section of this most excellent website, based upon my description, are there a few items that, historically, tend to be the most likely culprits to start with? Thanks
