XS650D
XS650 Junkie
I have the main jet and mid range dialed in pretty good on my 77D but seem to
have problems with my idle,one side (choke side) needs the fuel screw turned out min 3 turns with a 30 pilot jet to work and other side will work great with a 27.5 pilot and fuel screw turned out 1.5 turns.(I do realize that both sides should be same size pilot) have changed all the gaskets and butterfly shaft seals (used Genuine Yamaha stuff not Mikes.I tryed spraying some starter fluid round the carbs and noticed a major idle drop when sprayed round the spring on choke side carb "outside".
Has anyone used o-rings instead of butterfly stock seals for this,the stock stuff dosent seal very well.I definately have no leaks round the boots,sprayed them also,choke seals also good.Thx
