XS650D
XS650 Junkie
I want to install a set off the Front fork Dampers (Mikes xs) on my 77 .I reviewed some
info before disassembling,(Made a tool on a long extention with a 17 mil bolt head to remove or hold the piston rod in place while removing the allen bolt at the bottom) problem is after getting everything apart i noticed that mine has a different setup inside the fork.Looks like a nut head with only 2 strait sides.How do i remove this and will i still be able to use the Damper kit as the pics on installation show the damper sitting recessed into the top off the piston rod which i usume is under this special 2 sided nut.Thx
