angus67
Welder's penetrate deeper!!
http://www.mikesxs.net/products-38.html#products
Hi guys and gals! Was wondering if you all could help me on my carby problem with my 2003 Suzuki marauder.
A couple years ago, I did a baffle-ectomy to my 805cc Suzi, and sounds awesome!! Unfortunately, it stumbles and hesitates from 1/2 throttle to wide open. I usually pull out the enrichener before I run up a hill, but really getting on my nerves.
Here's what I've done to try to eliminate this problem. Have purchased adj. needles, and they are installed correctly, with proper spacers. This is the stage one cobra kit. It only came with needles and a drill bit for the emission cap. I thought that would be all I need, but, alas, 'tis needing a bit more fuel. These carbs are a total bitch to get at, one carb is under the gas, the other under the seat. This is why I've put up with it for 3 yrs.
I have been lately searching for some one with a similar set-up with a running bike. I found a guy that is running a baffle-ectomy, adj, needles, and 125 front MJ, and 135rear MJ. the stockers are 90 front, 100 rear. these are mikuni 36's. Now, the front jet is smaller in overall diameter than the rear, similar to Mike's smaller dia. and bigger dia. jets. See the link I pasted
My questions are:
Are all mikuni MJ's the same thread?
This jump up in size seems excessive, but its a better starting point than I had before.
even if the overall diameter is different, there is nothing in the way of installing the MJ's.
I'm thinkink about buying mike's jets. Ihave to get some for my 650 anyways.
Do you think this will pay off? Or is there significant differences in 650 jets compared to a more modern engine ? IE: needle seat, depth of jet threads.
Do you think I should buy a model specific jet kit, even thou they are way overpriced? Most come with needles, which I will have no use for.
Ive already tried richening it up by raising the needles, but it just pops, and snaps. Right now it has run its best in along time. This bike was a screamer till I tried to make it 'cool'.
I cant possibly afford shop time, but this is just killing me. the weather here in Washington state is gorgeous, and a friend has just bought a 2004 gixxer 1000. Sweet bike. 8k miles, paid 7k. near flawless, tipped over once.
I'm dyin' over here!! What do you think about this?
Its the one on the right.
My questions are:
