Question regarding Mikuni Hex shaped jets as used in VM 34’s and 36’s.
Signal
XS650 Guru
New Zealand
Regarding the numbering and the jet size. From what I have read the number is related to the amount of water flow through the orifice over a given time and not the size of the orifice.
Is it correct to assume that a #360 will flow twice the amount of a #180 jet if all other things are equal?
Good question. I thought it was related to the orifice diameter but maybe not so ... at least, not always! Hopefully the attached will help. Check out the bottom of page 5.
  • service_bulletin_carburetor_jets_2004-01-30.pdf
Thanks Nighthog, that is the info I was after. I will need to do some testing but now I am on the right track.
