DirtyErnie
Renaissance Hick
If you're working on the top half of your front brakes, above the lower brake line at any rate, and you hate bleeding as much as I do...
Take the caliper off the bracket and pads, and pump as much fluid into it as you dare, get that piston sticking out.
Then, when you're done with your work, push the piston back into the caliper and it will back-fill your lines from the bottom up.
Re-install the caliper on the bracket and pads, keep your master cylinder full and pump the system up.
Done.
Done.
