Soliddrummer
I installed the pma/pamco setup from mikes and made my timing marks as described in the instructions. The instructions say to make two marks on the side cover one is TDC, and one is at 15 degrees. The TDC mark gets transferred to the rotor. I assume that I will be timing it to the 15 degree mark, is that correct? The instruction left out this little detail. I initially timed it to the TDC mark and it ran quite well, which has me wondering if I should actually time it somewhere in between the two marks?
