Take a #2 phillips screwdriver, heat the tip with a torch until cherry red and plunge it into your eye. It will hurt less. Really. Bikes with CVs have airboxes. Bikes with slide needle carbs have pods. Even Mark Dobeck, former owner of Dynajet, cops to a loss of midrange using his kits.
Anything that makes a machine more difficult to service GOES!
And for the other eye heat a 3/4" drill bit chucked up in an air drill ...
I can get BS38's to almost work on the 650-700-750 with one serious caveat . They will pull hard with the throttle arbitrarily pinned OR they will mix fuel cleanly at part throttle cruise . Pick one I don't know how to give you both . Mark Dobeck and I went back and forth for most of a summer getting several of my customers bikes and my 998 (kaw) urban terror two wheeler running right . The customers are probably still pissed even though I neither recommended nor supplied this serious impediment to performance . In the end I knew neither was right (thanx for the flash runs Ron !) But the one that was the best and closest to right got me the most grief . That guy thinks I'm an idiot and in ten years hasn't wasted an opportunity to say so . Funny that the last two guys to touch it asked how I was able to get it so close . The one that isn't so good , that guy thinks I'm magic .
just a partial list
various attempts at
springs
needles
needle jets with and without discharge shields
pilots
mains
main air bleed
air horns within the air filters
closer to or further away from the head
adjustable cam sprockets
different headers ....
All because in one case the owner wanted to look like all the other cool kids
and the other thought it was a pain to get the carbs in and out with the stock aribox
coincidently both of these mental midgets went from 45-52 mpg to 30-31mpg and might have gained a couple of hp on top at the expense of having me spend untold hours filling a huge hole around 4k .
So I was asked recently if I would jet another for "pods" ( is it that hard to say individual air filters ? really?) good thing I kept my notes .
~kop
