For Sale - R1 Blue Spot Brakes and 320mm rotor
proeliator
Denver
Items For Sale:
$100 for the pair Shipped- Yamaha R1/R6 BLUE SPOT FRONT BRAKE CALIPER AND REAR BRAKE CALIPER WITH OEM MOUNT BRACKET
$150 Shipped- NEW 320mm BRAKE DISC/ROTOR (rotor has 6x80mm bolt pattern, ->correct bolt pattern for xs650 mag or spoke wheels)
There is a thread on this site showing how other members have done these brake upgrades. I am parting out my build and going another direction:banghead:
The bracket fits and will bolt onto 35mm forks, but it is made from ABS and I only used it to mock up the R1 calipers. I designed it in SolidWorks and 3d printed it as a prototype and planned to have it machined from aluminum. I made a spacer for the front hub and a bracket for the rear caliper too and would include these and the CAD files with the purchase of these items.
No, I don't have the R1 master, it wouldn't work well with only 1 front caliper (they run dual discs)
I do have a 13mm bore Ninja 250 master cylinder, brake and clutch perch fitted with some matching anodized blue shorty levers. The 13mm master should be about perfect for this application.
The stock rear should be fine.
I will let these go for another $100
I like the bike it would have looked great. I am only interested in the front caliper and bracket.
I know this is like 8 months old but I can't find the rear blue spot calipers anywhere. Where are you guys sourcing these?
If by some slim chance this is still for sale I will take yours, OP.
