I replaced the power transistior in the TCI box, still no change. I did some more testing, I ohmed the primary and secondary windings on the coil and they fell in spec, I have new NGK plug caps and they test good also. I verified ~700 ohms across the pickups, verified battery voltage at the coil, made sure the kill switch ohmed 0, verified battery voltage at the TCI module, verified a good ground for the module, etc etc etc. So I decided to see if the spark was going away when the engine begins to die. I did this one cylinder at a time (duh), on the left cylinder I had spark even as the engine began to die but it was a reddish weak looking spark, never any bright blue with a 'snap'. Then I went to the right cylinder and did the same thing, at idle I have the same weak reddish spark with occasional bright hot blue ones, when the engine begins to die I lose ~all~ spark on the right cylinder. Weird, since both cylinders run off of the same primary and secondary windings. But it's an indication of a bad coil so that's where I'm headed next.
