Okay, So I am building a chopper with a custom frame (GL chopper frame). This frame for one is not set to use stock components grrrrr. Second upon assembling the rear wheel and putting the drum brake on etc...I noticed that it was getting hung up on something and spinning the axle. Tried using a new axle and same thing. I then noticed that there was a lot of play in the wheel on the chain side. I noticed that the bearing on the hub side is snug around the axle. However on the chain side the axle moved around. This has to be my problem. My question is why is one bearing bigger on one side? The wheel I removed was a disc brake model and both bearings are identical. Am I missing a piece to make this work...ie special spacer or collar for drum brake models?
