jonny
I just rebuilt my set of BS34 carbs, but am having a problem. After I ride in higher gears, 4th and 5th at about 3500 - 4000 rpm when I come to a stop and attempt to start from 1st the engine almost dies when I give it throttle. If I let it idle for a bit (less than a minute) it seems to ride like normal again. Spark plugs look like a copper color, but not glossy. I can't tell if this is a fuel rich or lean problem as I've made adjustments both ways. Right now my mixture screws are 3 1/8 turn out and for the BS34 the needles only have one setting so I haven't adjusted those in any way. The needle jets are seated almost flush with the inner lip where the main jet screws into it in the bowls.
