Reed valve crank case breather (Heiden Tuning)
Leslie
XS650 Junkie
XS650.com Supporter
Sherwood North Nottinghamshire UK
Hi has anyone fitted one of the Heiden Tuning crank case filter, which is half the size of the OEM item, nothing wrong with Yamaha's set up, I'm just a bling bitch. Fitting a K&N filter.
Best to plumb it to a catchcan, oil will still bypass the petal. I build all my own stuff, the catch can is mounted behind the gearbox over the swingarm pivot. Catch can has four baffle plates, some stainless scrubber material and finally a foam filter.
Some mount the catch can up high so that they can drain the oil back to the crankcase after it settles out of the mist.
That would defeat the purpose of the catch can. The oil has blowby debris mixed with it. Only the air exiting the top after passing the baffles is clean.
One option is to route the tube down through the rear engine mount plate hole towards and above the chain.
Although I’ve not noticed a visible drip.
Im not sure that all the NASCAR crew chiefs (who all run dry dumps with basically this setup) would agree. All engine oil has blow by debris mixed with it but the reed valve makes the rings seal better and therefore has less blow by debris than a motor without one, and all that oil stays in the motor and is recycled.
Agreed. Really don't want what is mostly emulsion/water with some oil draining back into the engine.
Where exactly is the oil picking up water to create an emulsion? Especially mostly water? Even on the most humid day the hot catch wouldn’t reach the required dew point to condensate water vapor out of the air. Please explain I’m not sure I understand.
Well, you said it,, all engine oil has blowby debris mixed in it.
Crankcase blowby gasses contain soot, unburnt fuel, exhaust gas particulates, carbon, water, acid. Plus probably a heap of other particulates. Ideal stuff to lube your chain with. Air, the stuff drawn in through the carbs, is made up of Nitrogen, oxygen and argon, it also contains up to 4 percent water vapour, depending on location.
>4% water vapour at a 14:1 ratio is about .07% which 99% goes out the exhaust valve, this will not cause the oil to emulsify, and certainly is not a concern when recycling the oil for 1000 miles. If your oil is a milky emulsion when you drain it you have been riding through a swamp!
By returning oil from a catch can to the crankcase you are not doing anything different that the engine does anyway. Depending on how much oil you can capture from your crankcase vent it may keep the oil level from prematurely running low.
It does not help seal the rings.
There's bevels on the two compression rings. On the top ring, compression pressure pushes the ring tighter against the cylinder wall. Similar story on the middle ring, but slightly different. More crankcase pressure = less pressure differential across the compression rings = rings don't expand for full sealing = cylinder pressure loss, MORE blowby, and possible oil consumption. Suzuki gsxr motors try to alleviate this pressure under the piston and create a larger pressure differential by casting a window between adjacent cylinders so that that piston going up, sucks the pressure out from under the adjacent cylinder that is on the combustion stroke.
It’s not quite a vacuum like the reed valve can create but it helps.
Well,you know it all, who am I to argue with one so knowledgeable.
Another to add to the idiot list!
https://www.xs650.com/threads/crankcase-vent-using-a-reed-valve.61188/
@toglhot
How does the crankcase vapor know to separate out the water and "combustion byproducts' and send them to the crankcase vent?
In a picture from the link you provided; after 9 months the accumulation looks perfectly normal, no solid by products, no water. This was an open bottle with a hose going in the top (common on road race bikes), vapor goes up by the hose, out to the atmosphere and oil drips out the hose to the bottom. In big bore turbocharged drag bikes they have multiple vents going to a aluminum can with various baffles (mostly plates with chamfered holes to separate the air from the oil), and another baffled hose outlet (out the top) going to a filter for the air to escape then, the de-aerated oil drains back into the cases usually through a fitting attached to the oil fill hole, they have never had a problem with water as far as I know.
I would attach a pic but for some reason the button is greyed out.
