For Sale - REG/REC
member3480
RICH
NEW JERSEY
I have a couple old style and new style REG/REC
and if you want the wire setup I have some of them too from Alt. to reg/rec
REG/REC old style two piece $30.00 shipped in USA
REG/REC combined $40.00 shipped in USA
Wire setup from Alt. to REG/REC $25.00 shipped
Also found a box of started harnesses (you Finish) $75.00 shipped in USA
Cleaning out some parts for move from my home.
What do you need!!!!
Had some questions on the harness in add THESE ARE NOT COMPLETE you have to do some work.
BUT IF YOU WANT A CUSTOM ONE
Here is what I offer
STANDARD one KICK ONLY
3 wire HEADLIGHT HIGH-LOW-GROUND
3 wire TAIL- BRAKE-RUNNING LIGHT-GROUND
HORN- 2 wire HOT-GROUND-with switch
Wire Loop for charging System (6-7 Pin??)
2 wire for Coil-Ignition (STOCK-PAMCO-BOYER)
Brake Switch (DRUM-DISK)
Grounds and Hot's for battery
SWITCHES 3 position lights-push horn-2 position ignition
ALL WIRES SHRINK WRAPPED
CUSTOM HARNESS
All of above PLUSE Electric Starter Setup
Fake Oil Tank and battery box or Small Beer Keg
All switches attached and 12 pin plug for quick disconnect
CUSTOM PLUS HARNESS
ALL OF ABOVE PLUS
FRONT/REAR Lights/HORN NEW!!!
with TURN SIGNAL and SWITCH NEW!!!
Hope that clears some questions Prices start at $125.00
Takes three hours to make a nice harness try it sometime.
I also do other bikes too CB KZ Harley:thumbsup:
KEEP CHOPPIN:D
