I_ride_forth
Hi all,
Really struggling with an electrical issue that I could use help with. I have a 1975 XS650 and it's in generally good condition. The previous owner had installed a newtronics electronic ignition but hadn't refurbished any of the rest of the electrics.
The original wiring harness had corroded and I was getting a few shorts where wires had melted in the headlight bucket so I replaced with a new harness form Yambits.
I connected up as labelled in the wiring diagram but when turning the ignition switch to position 2 had smoke coming out of the Right hand switch and the wires from the switch were melting. Thought it was the switch so bought a replacement but the same thing happened again now I'm two switches down and rather confused as to why they keep going up in smoke.
Any ideas what may be causing this? Also id have expected the fuse to have blown first there was a 35Amp fuse in the main fuse which seems rather high? What should the main fuse be on a 1975?
Any help would be much appreciated!
