roadstar06
hey guys, I'm still putting it back together now I have more questions-#1- from block out washer sequence I have = 1mm,2mm,slide bushing,basket,1mm,bearing,2mm,hub,spring washer,tab lock,nut. right or wrong? manual and chilton only show bearing and 2mmwasher- when installed that way basket has play-when installed with 1mm,bearing,2mm no play...#2-should I be able to push clutch rod by hand to release clutch? because I can't and it doesn't turn either. new long rod installed,ball bearing then pc that makes contact to push hub cover..#3- chilton says 54-58 lbs for nut-yamaha says 94#s which is it??
