I'm working on an 80 special and not sure if my problem is electrical or a fuel problem. It starts easily, and idles smooth, but when I try to rev it up, it becomes very rough and won't rev up higher than about 2500 rpm's. I have had the carbs off and all the jets and passages are clean on the bottom side, but I didn't take the tops off or do anything with the slides. It's getting fuel ok, I just put on a new petcock, inline filter, and clear fuel line.
Thought maybe it had something to do with the timing because someone recently put on a new rotor, but it starts very easy, so I don't think it's the timing, but I don't know. I also adjusted the cam chain, valves, and put new plugs in, but I am not sure what to check next. Thanks for any help.
