barrycastle
Hey all, I picked up this 1980 XS-G a couple of months ago and I have since taken off some OEM parts and I'm about to remove quite a bit more. I've attached a few pictures to show the bike when I got it, and a list below summarizing what is available:
-Matching tank/sidecovers, green metallic with silver scallops... looks nice! Tank has new mikesXS "non-vacuum" petcock
-Seat
-chrome front fender
-16" rear wheel, no bearings or drum brake assembly (tire is old, and will be removed)
-taillight/tag assembly
-exhaust pipes (chrome is pretty good, a little rust on the crossover pipes and on bottom of pipes, hole around bottom lip on both pipes)
-TCI ignition module with coil, works great!
-Gauge cluster
-OEM handlebars
-Turn signal switch
-Throttle/kill switch
-OEM rotor (the stator is what tested bad)
-OEM regulator
-airboxes with crossover tube
-all oem relays, safety fuses, backup lighting module, etc...
-battery box
All of this stuff is make offer! Please let me know what you're interested in and I will get more detailed pictures for you.
I will ship any of it, and I am open to trades for other parts too! The main parts I need right now are all the advance/points parts including the shaft.
-Seat
-Gauge cluster
-OEM handlebars
-Turn signal switch
-OEM regulator
-battery box
