mistercartoon
Hi all, so i scored a 447 motor that a bloke basically just took the head off & it never went back together.
He said it was a really good reliable engine but he wanted to do the cam chain as it had never been renewed & he wasnt sure what happened to the stator & rotor,but its gone...so here i am, with a spare new chain & a pma kit from hugh but not really a good idea where to start.
can we just assume for now that that yes the bottom end is fine & i just need to get the pma on (correctly) & fit a chain, all in correct positions.
what would do first? fit the pma to the crank & find tdc (unsure of how to do that correctly with head & barrel off) & then somehow use the marks on the cam to fit the chain?
i had planned once i got to this point to pull the bearing off the cam ends & slide it on.
Id really appreciate some advice & if this has been covered somewhere else, well...ive only seen bits & pieces not entirely suited to the spot im in.
thats great. thanks
will add pix soon
thats great. thanks
will add pix soon
