AllanCaveNZ
Hi guys,
I've got a '79 xs650 special and just installed Pamco ignition with MikesXS dual output coil (black one not green one) and Mikuni VM34s from Michael Morse along with a new PMA. Problem is when I've gone to kick it over it revs realllly high straight away, weirdly enough it won't kick over if I only have the left carb choke on but will kick over if I have only the right carb choke on.
I didn't see any instructions on which output from the coil goes to which sparkplug but I've tried it both ways round (is there a correct order?) the throttle cable and slides seem fine, the advance springs have tension and snap back nicely, no obvious vacuum leaks, cleaned the spark plugs, tried the Pamco with timing retarded fully and it slowed down a little but not a lot, set it back to the middle after that tho.
Could I have installed the pamco incorrectly at all? It seemed very straight forward. The carbs should be set up reasonably enough to get started okay as came from 650central with vacuum barbs and jets adjusted, could I dial down the idle or air screw to see if it makes any difference?
Valve clearances set, cam chain tension checked etc.
Any advice appreciated, I'm away for a couple days but will try check from my phone. I'll put a pic of the bike up if no one abuses my use of massive firestones ; ) still a work in progress... I'm in Melbourne, Aus.
Thanks!
Allan
Thanks!
Allan
