groundsfordivorce
Hey guys,
Rewired the bike (1977 XS650 with an updated electric ignition, not points), starter motor engaged...occasionally it would make a god awful grinding noise but MOST of the time the pistons got chugging away like they should.
Added gas, and basically I got fire leaping out of the exhaust ports and smoke coming out of the air filters...gasoline was dripping from the air filter ports...banging and smoke but nothing that sounded like it was gonna take.
Ok, so the grinding noise I dunno - I took out the starter motor and nothing looks worn...no metal shavings or anything terrible and for the most part the starter was doing it's job...not perfect but it was something. Maybe someone has some insight to make sure I don't wreck the transfer gear on this thing.
The larger issue is the ignition...friend of mine suggested that I have the spark plug cables the wrong way around...the spark is firing too late for that side and igniting the exhaust. I thought that the bike might be a wasted spark design tho in which case it wouldn't matter...But it's a quick fix once I get this thing back together, so I'll try swapping the cables. Anyone think that'll work?
Floats in the carbs appear to be free moving...I opened up the throttle too much while testing so I KNOW I flooded the engine, but like I said I don't think the carbs screwed me.
Anyway, before I go into round two I'd appreciate any ideas. Thanks
