RadMax
So I’ve got a 1980 XS650 Special, couple miles on it... To make a long story short, the splines on the shift shaft rounded off a bit, and it won’t go into gear, the shifter rotates on the shaft with both shifters. I tried replacing the toe shifter, that’s not the problem. I know it’s weird for the shaft to wear out and not the shifter. Anyway, since this part of my manual is missing, and I’ve got two spare engines, what do I need to do to replace it? Do I need to remove the clutch?
