So you're going through your spares looking for a couple of good enough direction lights for a beater bike and you see a couple tired ones, you know a bit scuffed, bent and having the wire stop right where the hollow thread does. You can't even stick a butt connector on it (not that you would do such a thing).
Taking it apart, the fix looks easy, just solder a fresh terminal onto a new piece of wire, but where do you source that terminal that has been crimped on and cannot be reused.
I found a red spade terminal with a tiny hole in it and trimmed it to a small cicle. The little hole is just big enough to let the bare wire through, but sits up flat on the insulation, making it easy to spread out the filaments and solder them onto the bitty "washer".
If you assemble the wire, socket, spring and the big washer before you solder it together, it is a whole lot easier getting the new wire down the hollow mount thread. If you want to get really fancy you can get a green or brown wire off an old harness and be factory colour coded. I grabbed a blue piece, I promise to put a label on its business end before installation.
If there were a ready source for those small terminals, the fix time could be reduced to minutes.
