Should I replace my oil pump??
Triggerton III
England
Hi guys
Have a look at these images should I replace the oil pump?
Thanks
The bike was a none runner when I bought it and there was no sump screen present. I will check the magnet idea to if it aluminium or not. That would be purely academic now as I have stripped and rebuilt the engine. The cam chain guide was heavily worn. Piston 2 was scored and the outlet valve on piston 3 was bent.
I vaguely remember seeing some manual where some inspection routine could be found
Measurements taken and so .Dont have time right now to search for it
In my Haynes manual there is description -- measurements to be taken for a check feeler gauge
Most likely also can be found therein
https://thexscafedotcom.wordpress.com/2011/01/10/xs650-manuals/
Get back if you cant find it
Also out of memory I don't think a replacement is to expensive.( can be wrong )
