chrisbuckart
Hello, I have recently swapped the stock ignition switch on my 1978 650 Special with a TC Bros simple three wire ignition switch. I thought this would just be a simple swap, but it's not been quite as simple as expected. I'm working with three wires, Brown( turn signals and headlamp fuse), Blue (tail light), and red (ignition). The back of the TC Bros switch has three points of connection labeled ST, B, and G. My first hurdle is not really knowing which wire goes where. I've not been able to find much info on this as well. So I began making connections and noting them, as well as what was working and not working when the ignition key was turned one click, then the second click. If I'm understanding how this new ignition switch is supposed to work, I believe one click turns on everything except ignition. And the second click allows me to start the bike. Long story short, I've wired the switch pretty much in every combination possible with the three wires and none of them are working as it should. I'm able to get power to everything (2 clicks)but the brake levers are not activating the brake light. But when I take it back to one click no power to anything but the brake levers activate the brake light. It's probably a simple fix, but I'm pretty in experienced with the electrical system and find the wiring diagrams difficult to read. Also the bike has a pamco ignition installed and I have removed all of the unnecessary little black boxes. It's been running great until I swapped the ignition switch. Any advise would be greatly appreciated. Thanks gang!
