slugs, where to buy them?
emzdogz
Aunty Em
Tampa, FL
Do you just buy solid steel rod and cut it in lengths you need? Do people sometimes use thickwalled tubing as slugs, whose OD = the ID of the tubes you want to weld together?
I want to try re-working an old pair of z-bars I have (make 'em shorter and have more pull-back), and am wondering where to source slugs.
I thought if the only purpose of the slugs was to pin the tubing together while welding, then a couple of pieces of whittled-down re-bar could just be hammered in, but really, it would be nice to have better-fitting material.
thx!
Typically we use solid but there's really no reason you can't use tubing. Just make sure its a snug fit or it will twist when welding.
If I wanted one I would go to my local steel/junk yard. They have stuff that I can buy for scrap prices. Most of the stuff I need isn't large. You could try HD or Lowes, but I don't know the status and if they had anything like that it will cost you more than the scrap yard for sure.
