Could You guys help me on how to test a Solar Panel.........I search and found this Youtube Vid and to me it seemed right......But who am i to know.........
one of the comments posted said the guy was wrong and in order to test it needed some diodes set up????
Now i need some expert opinions i can trust
I have my Volt Meter.......It will test up to 1000V DC and it is 10A Max.......
.By the vid i will have no trouble testing the Voltage of the panel, (setting my VM to the 200V setting).
Panel Detals highlighted in Blue-Red-Purple
Question is it ok testing the Amperage with my VM as the Panel is rated
8.4 max power current-Imp A and
8.8 on the short Circuit Current-Isc A,
Being less then 10A i think it should be good to go.......Need assurance/confirmation
What i want to do is build my own Hot water system by using a 12 Volt heating element running off the Panel through a 12v battery/system.....Because the Panel is rated 30.5V and 37V open Circuit, (Q; don't understand what the difference between the Voltage as 30,7V and open circuit 37.8V ??)............
The Ground/earth is done through the Panels.
I assume/think i would need a regulator and rectifier, (as per our bikes system), so as not to cook a battery and to convert to AC from DC.
Any help appreciated.
PS; Did the youtube vid post up.???........for some reason my computer is not showing and vids posted by anyone through Youtube
