Speaking of welding...
Downeaster
Everything in XS
Downeast Maine
Disclaimer - What little I know about welding is self-taught through trial and error. Lots and lots of error...
Still, I flatter myself that I'm at least a short step above a junkyard welder.
Right now, I'm having my ass soundly kicked by a project. I need to weld some 1/4 inch 316 Stainless rod and I can NOT get TIG to work. I'm using "red" tungsten, pure argon, DCEN and have tried both larger and small gas lenses and tungstens. All I'm managing to do is create a bunch of black, crumbly birdshit.
I initially thought the fact that I was clamping the rod to a steel table was introducing contaminants, so I tucked a sheet of scrap stainless between the rod and the table - no change. I've been all over the dial on amperage and pre and post flow and nothing is working. Is this some sort of issue with the 316 alloy, or have my TIG skills (sketchy on my best day) deteriorated to complete crap?
I have some 1/16ths 308 stick that works okay and is getting it done but it's beyond ugly. Should've got some 1/8th I think that would have helped.
Of course about the time I came up with a way to hold things in place and got the stick welding method to work at least somewhat, the friggin' batteries in my Miller helmet died and I only have one spare...
Do you have a city college near you?
I took a welding class at night a few years ago. Cost me 30 bucks.
They had top quality equipment and very skilled instructors.
People from all walks of life.
It really helped me. I’ll probably go back in a year or two when I have some free time and take one specially on tig.
I took an intro class but it gave us a few weeks on oxy, stick, mig, flux and tig.
Using your TIG can you form a good "puddle"? Does the black crumbly stuff form when you add filler rod?
@GLJ - Yes...
I'm welding two pieces of 1/4 inch rod at right angles ┴ so the joint is really tiny and while I can establish what looks like a puddle on either piece, I can't get them to flow together and as soon as step off the pedal the black crud forms. With or without introducing filler.
sounds like gas envelope is cutting off too soon or there's too much air movement. The black sugar is oxides...I've ruined a few ss projects, and also built a lot of stainless in US canneries, union work, and I was sometimes the first choice...which was silly, but it happened. As to self-taught. Me too. Longtimeago an old millwright told me that "nobody can teach you to weld" by which he meant teach yourself. I too took a class. I learned a lot. Best!
It sounds like a gas problem. Can you increase the amount of after flow time? Also make sure you are not welding in a breeze.
I always wanted to make a gloved box from an aquarium and fill it with CO2/argon, then do tig with no cup - It'd have to conserve the gas mix, ie be tight with slight overpressure flow. Maybe someday, maybe not. But for little things it'd be larrupin'. Maybe CO2 alone but with the argon-cup thingie too. Phuckaround/findout. Simply musing on the idea.
I never had trouble 308 / 316 so far as appearances, nor mild steel to 316. But none of that was structural or motor related as in where it actually matters.
Best!
I know this thread was to discuss TIG welding, but I thought some experts watching this may be able to help with a few stick welding questions. I had lunch with a friend today who gave me about 10lbs of welding rod UTP 65. I Googled the rod number and it appears to be a decent rod. I think the biggest issue I have with them is they have been stored for decades in a cardboard box in a less than dry environment. I wonder if these rods are salvageable. I read they can be baked to dry them out but being so old, is this an option for me? If that can be baked, can this be done in the kitchen oven or will my wife shoot me for trying? It would be nice to save them if it’s worth it otherwise I’ll just pitch them.
Any experience with these? Thx
Sounds like a great girl's night out project, ;^)
Shouldn't stink and seems like rod coating is pretty tough. Haven't stick welded for..... well nevvver mind that.
Back in the day a 25 pound cardboard box of rod could sit out in the shed forever and still weld just fine..
Ok I may try it in the oven but tell wifey in advance that you said it would be ok. lol.
My welder is buried in the garage right now but when I have a chance to pull it out I’ll try burning a couple without the drying treatment.
As for old rods/ sticks, I would recommend drying them out immediately before using. Otherwise they will just absorb water from the air again. On all the ships I have worked on over the last 22 years, we have had a heated thermostat controlled cabinet for welding rod storage. When a new pack is taken from the main storage, and opened, it is put in this heated cabinet. Except for buying new vacuum packed rods every time, this is the only way to do it properly.
Do you what temperature they were kept at?
I'd say we keep them at 60-70 C, as the humidity in non-aircondition areas on a ship is often very high.
According to the specs from Unitor, the thermostat range is 86-185F. See attached screenshot.
When I worked in a shipyard 35 years ago, the welders had portable electrode "buckets" with a heating element. About the size of a 5 gallon/ 20 liter engine oil bucket/pail. Something like that could be useful for hobby welders.
