Hello,
So I have a 1975 XS650 and I have been messing with carbs a little too much I think. I started out by changing my needle position not really sure why, I think I had tried everything else but that. So the clip is in the center where it used to be was 1 slot below the center. Now I have cleaned my carbs like 4 times cleaned everything. It was running better but when I put it in 1st and pull back on the throttle it sputters then dies and when it doesn't die it sounds pretty choppy.Perhaps its a fuel screw setting? I also put new plugs in yesterday and they are gapped right. Should I go back to the original clip setting? I also did my valve lashings about 2 months ago maybe I should recheck. I also have large capasity fuel filters on which are the wrong size they will work but there is a mild kink in the hose. Maybe I could put my old fuel filters on which are the right size but then I don't want to get any gunk in there from old fuel filters
