CoconutPete
1979 XS650 Special
So I started installing my PMA tonight. All was going well until it came time to remove the stator assembly.
The instructions recommended using an impact, so that's what I did.
The first one was stubborn, but jjuuuuusst made it off before it morphed into a useless screw.
The second one moved, but stripped before it came loose. Tried vice grips - no luck. Tried a screw extractor... even bigger fail! Basically just drilled a conical hole in the screw.
Based on the other screw there's a decent length of rod back there without threads ... so I'm thinking maybe drill it and attack it once the stator assembly is off.
What does the wisdom of the board think?
